Wall foundation VG n gap
yes_and_no
yes_and_no
Guys,
How can I control wall foundation (structure) in view template ? I m sure this can be done because I can change their graphic rep by elements.
Also, due to door locations sometime the wall foundation automatically creates a gap. This gap in turn can be ungap by dragging either end, but never completely joined like that of normal architecture wall. Is there a solution to this ?
GHASEM_ARIYANI
hi
in the type properties of Wall Foundation > uncheck Do Not Break At Insert.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
yes_and_no
Great,
Do you know how to assign their graphic appearance to view template ?
GHASEM_ARIYANI
Look at the numbers in the picture below:
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
yes_and_no
I don't think you can do a straightforward VG setting without a VG filter...
Thx anyway
Not clear what the problem is.
yes_and_no
For line type, ít won't work in view template (plan), in my project. I have to create a filter, not a big deal, just curious if it the same to everyone.
