Wall Footing with Vertical Offset
BigPicture045
BigPicture045
Please see the highlighted wall below. As drawn, the wall protrudes into the 4" concrete slab. I need the wall to set on top of the 4" slab, however, I need the wall foundation which is attached to the wall to stay where it is.
I am looking for an offset feature for the footer so I can keep the footer where it is, but raise the wall up 4" so it sets on top of the slab.
Known workaround: Use detail lines to show desired section.
syman2000
Typically I would use join geometry between floor and wall. So the wall will be cut by the floor slab.
Kind of depends on the construction.  Are you thickening the foundation at the walls, or erecting walls/foundations first and pouring the slab later.  I'm seeing the condition more like this based on your description.  Walls on top of foundation.
Essa condição é mais adequada, visto que a fundação se refere a sapata corrida, logo à anterior uma sapata isolada.
