Wall End Fillets?
2 REPLIES 2
vimQQ4GW
247 Views, 2 Replies
Wall End Fillets?
is there a way to "pill"/fillet the end of walls without using model in-place wall voids? this is for a 3D printed structure, please see image attached for reference.
2 REPLIES 2
in reply to: vimQQ4GW
Place a circular column at the wall end for the true rounded ends. Place a void column family at the corner for the smaller radiused corners ( I usually have a void column family with an instance radius parameter).  Or model thin walls around as you show the layers.
vimQQ4GW
in reply to: ToanDN
this works, thanks a bunch!!
