I can't get my line to show on a legend view as it shows in my plan view. Do filters work the same on legend views as on regular plan views. Is there something special I should be checking in VG?
Solved by ToanDN. Go to Solution.
Is that coming from the Wall's Coarse Scale Fill Color/Pattern? Is the Legend Coarse Detail Level?
The legend is same detail level as the plan view, coarse. The scale is the same.
Check under the properties of the individual Legend Components themselves. Is Detail Level set to By View?
The wall patterns in the plan view are from filters, not from Coarse scale cut patterns. Please use Coarse scale cut patterns then you will see them in the legend view.
I did read your question, and the detail level of the view, legend and legend item were all the same. The cause of my issue was that I was using filters to get my pattern.
@David125 wrote:I did read your question, and the detail level of the view, legend and legend item were all the same. The cause of my issue was that I was using filters to get my pattern.
You clearly did not read my question. I never mentioned "detail level" in second reply. In both my replies I mentioned Wall's Coarse Scale Fill Pattern/Color.
Whatever. I'll try using ALL CAPS the next time I reply to a question of yours. Maybe that'll help. 😉
