Message 1 of 8
08:25 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi to all, i am a student trying to learn revit.
I created a model and I had a weird problem. I designed a rectangular room and all walls are joined fine as well as the wall corners in plan view. But when I create a section box in 3D the "cut" walls' corners are not showing as joined. I provide you with screenshots so that you can understand what I am describing. A temporary solution was to change joint connection to a miter corner but I hope there is a better solution. Thanks for your time!!
