Perspective view is cutting through the object
Hello there!
I'm new to Revit. I've been using Revit for about two months now. Anyway, I hope you're kind enough to answer such as this basic question.😁
Literally, I have no idea what kind of problem that I face. When I turn my 3D view and start using the navigation wheel to zoom in and out my object, the thing goes wrong. As you can see at the image below, something mysterious is cutting through anything within the object. The thing that I am able to do right now is just use the orthographic, since the issue doesn't occur in this view.
I just want to know how to make this thing right. I've searched the solution to this typical problem on the internet. But, I haven't found the right approach yet. Maybe, It's just because I really don't have any idea about the right keyword to explain this kind of problem.
I hope someone will read this. And I will be so grateful because of your will to response.
Ilic.Andrej
Play with these parameters:
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
It's working. Thank you ! 😁
