Wall components change thickness when doors inserted or joined with columns
7 REPLIES 7
Message 1 of 8
396 Views, 7 Replies
Hello, I am using Revit 2019 and am having an unusual problem which I couldn't even find on a forum before. For some weird reason, when I both join a wall to a column and insert a door or window in it nearby, the thickness of the wall components automatically change. If I erase the door, or unjoin from the column, it goes back to normal. I'll upload some screenshots for you to see what I mean. In the second one, even though it looks fine, the column is not joined with the wall. I'm having the same problem with various walls in my project.
Thanks!!
7 REPLIES 7
Message 2 of 8
dferreira-blackwell
I tried but it doesn't happen in mine. If possible can you list the steps to reproduce this issue.
Message 3 of 8
in reply to: dferreira-blackwell
The structure was the first thing I modeled. When I model the wall there's no problem at first, the problem happens once the door/window is inserted in the wall and I join the wall with the column
Message 4 of 8
dferreira-blackwell
I tried doing the same way but no issues to report.
Message 5 of 8
Do you think it may be possible it has to do with my specific file? Like maybe it's corrupt or something of the sort.
Message 6 of 8
I have had it happened in an older version. What version are you?
Message 7 of 8
dferreira-blackwell
Maybe but can't say for sure. Try this open new project and just copy paste this element structure wall and window. see what happens there..!
Message 8 of 8
Well, Joined elements do share the same line weight.  Is this what you are seeing?
Forma Design Contest
