Wall Chamfer
Wall Chamfer
Wall Chamfer
I am new to revit!. i have 25 years experience with Autodesk AutoCAD and Architecture.
I have a 400 wide 1100 high concrete wall with a 250 thick slab forming my cable basement, the walls project 200 above ground level. for aesthetic reasons i would like to place a 25x25 chamfer around the top external face. I would appreciate any Help Please!
rodrigo.bezerra
Do you mind to upload a quick sketch to illustrate the concept?
Rodrigo Bezerra
chrisplyler
Create a triangular profile family using the Profile - Reveal.rfa family template. Create parameters and types for different sizes if you want. Save it with a unique file name. Load it into your project.
Edit the structure of your wall. Turn on the Preview window, and set the preview option to the Section setting. Click on the Reveals button, add a new reveal, set its profile to be the triangular one you created, and set it to be zero distance from the top of the wall.
Thanks Chris, sorted, worked a treat
Kind REgards
Kevin Atkinson
EnServe Group Limited
