Volume and surface calculation for a concave roof
Message 1 of 9
Hello all
I am trying to calculate the total volume and surface for the roof structure of a complex tent-like building with a concave tent-like roof by first defining the areas in 'Schedules/Quantities' and then using 'room & area' menu in architecture tab. I fail to generate the result and would appreciate any help with the attached model (not my creation!).
Best wishes
M
Replies (8)
Message 2 of 9
@Anonymous wrote:
Hello all
Best wishes
M
Have you tried getting info from the dwg file the tent portion came from?
Message 3 of 9
Unfortunately I don't have the original dwg files. The Revit model is all that i was given ...
Message 4 of 9
loboarch
In order to do this in Revit, you will need to figure out how to get the room geometry into the model as a "real" Revit element that can be used as room bounding, otherwise the room elements and area elements will not recognize the roof geometry as an "edge".  The DWG import symbol has no notion of "enclosure" it is just pure geometry.
The massing tools in Revit can make shapes like this, but I don't have a magic answer to get the exact shape using those tools either. Perhaps others will have some suggestions to get something close to the shape of the imported DWG file.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 5 of 9
Hi Jeff
Could I just make sure that I understand you correctly...
The detailed Revit model that I was given cannot calculate the volume of the space I'm interested in because inadequate info is inherited from the original DWG file, is that correct?
Surely if a Revit model contains tens/hundreds of thousands of coordinate points stored to be able to generate a complex 3D model, the same coordinate information could be used to do a run-of-the-mill volume calculation?
Roy
Message 6 of 9
@Anonymous wrote:
Hi Jeff
Surely if a Revit model contains tens/hundreds of thousands of coordinate points natively created in Revit and stored to be able to generate a complex 3D model, the same coordinate information could be used to do a run-of-the-mill volume calculation?
Roy
Message 7 of 9
loboarch
@Anonymous wrote:
Hi Jeff
Roy
The problem is the "roof" in this case is made from a DWG import. This works for the pure geometry, but Revit does not know it is a "roof" it just sees geometry. The reason this is a problem is because Revit needs to be able to know if this thing is a roof so it can assign a property to the geometry so Revit knows it is "room bounding" this room bounding property is the key. when the item is room bounding then the room object know to stop when it intersects this geometry. Without this property being set then the room just keeps on going ignoring it. Unfortunately there is no way to tell an imported DWG that it is "room bounding". That designation can be applied to native Revit objects, more specifically, walls, floors, ceilings, and roofs. Objects in other categories can't be assigned the property room bounding.
So that is the trick. You need to figure out how to get that DWG geometry into one of those Revit categories using native Revit geometry. The 2 most direct approaches would be an in place model assigned to the roof category and use the DWG geometry as a guide to help re-construct. This might be tough as the shape does not lend itself well to the shapes easily made with the in-place tools (solids models). The other option would be to create a mass model either in place or as a component family that could then be used with the roof by face tool in Revit to generate the roof based on the mass model. This is by no means "easy" but it is possible.
Jeff Hanson
Revit Help |
Message 8 of 9
The problem with this particular imported DWG is that the surfaces are polymeshes which are not possible for Revit to create roof by faces from.  If you have access to Rhino and know how to use it, you can export the Revit file (with only the imported object visible) to a DWG, open it in Rhino, and re-build it as NURBS.  When done, export the NURBS to a SAT file and imported it in Revit as conceptual mass or in-place mass.  Then, you can create roofs by face to form and calculate Room volumes.
Message 9 of 9
Dear Jeff and Toan
Thank you both ever so much for taking the time to write a detailed reply. Being a building physicist I shall then keep to my energy modelling! I will pass this to my colleagues in architecture to deal with ...
Thanks again,
R
