Area colors are covering my furniture
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
4784 Aufrufe, 4 Antworten
The first sheet of my document (as well as all of the rest) has furniture, and colored areas. When I look at my screen, I can see everything just fine, but when I go to print the only thing that shows on this first page is the area colors (no furniture). Every other sheet looks just fine. It is almost like the area is covering the furniture in this one sheet. Is there any way to fix this? I've tried making new areas and deleting the old ones, among other things, but nothing is working. Please help!
4 ANTWORTEN 4
Nachricht 2 von 5
loboarch
als Antwort auf: Anonymous
Try changing the color scheme location in the properties of the view where it is wrong. Move it to the background.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 3 von 5
als Antwort auf: loboarch
It was originally set as background, I switched it to foreground and then back to background and it worked perfectly! Must have been a glitch in the file, thank you so much!
Nachricht 4 von 5
m.mcnally4323
im struggling with the same problem. I've tried toggling the foreground/background tab and still my furniture is covered? is there another work around?
Morgan
Nachricht 5 von 5
als Antwort auf: m.mcnally4323
You furniture families either has only lines visible on floor plan, or the category is set to transparent.
Open the family and check
