Void visible after cut
6 REPLIES 6
andre.micka
681 Views, 6 Replies
I have a problem with voids.
I have created a solid topo from Civil 3D and imported in Revit.
I have created a Void family to cut this topo volume but, even if the family cut the volume, the void still appear...
Can someone tell me why ?
Thank you
6 REPLIES 6
andre.micka
in reply to: andre.micka
Ok I have found the problem.
Iy is from civil 3D surface. ..
hmunsell
you could import the C3D topo lines and use those to make a Revit Surface.
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-D7C6E4AF-D902-478D-92C2-CD2DCE338426
Then you can use the split surface or Building Pad tool as needed.
Howard Munsell
andre.micka
in reply to: hmunsell
Thank you for the link.
But it is possible to create grading with specific slopes (1/1 or 3/2 for example) in Revit like in civil 3d ?
I don't have him 360 to link topography between c3d and Revit
hmunsell
not that I'm aware of. you can make a surface by placing points or drawing lines and different elevations, but Revit is not a "Civil" program. to my knowledge you cant assign a slop to grading in Revit.
we do not have BIM360 yet either. you should be able to use the Desktop Connector tool to get your up-to-date files from BIM360.
https://www.autodesk.com/bim-360/desktop-connector/
Howard Munsell
andre.micka
What do you mean? If I install desktop connector I can link the c3d surface to Revit like bim 360 but in local?
hmunsell
the point of Desktop Connector is for people that do not have a BIM360 license to post and download updated files from BIM360. we have had to use it on a couple projects. I do not know how well it will work with a C3D file that is hosted on BIM360. you'd have to try it.....
Howard Munsell
