Void On/Off Parametric Formula
cwilliamson232RQ
Message 1 of 10
cwilliamson232RQ
I need some help writing this  formula. I have a Void On either Side of this Component but want to be able to turn them on and off by a check box. What is best way to do this? See attachment.
When I select Side 1 Location I want to see the Void on Side 1.
When I select Side 2 Location I want to see the Void on Side 2
Replies (9)
Message 2 of 10
You can't turn off the Void if it's attached.  You'll require two different cut geometries, then you can use formula to control which geometry is visible.
...another approach might be to add geometry instead of cut geometry.  That could be controlled through a Visibility parameter.
Message 3 of 10
cwilliamson232RQ
Ok found a workout around for my original question but now I have another question.
If I have 4 Selection Yes/No Boxes and want to only be able to Select 1, how does that work?
EXAMPLE:
HEIGHT 8
HEIGHT 9
HEIGHT 12
HEIGHT 21
Message 4 of 10
Use an Integer parameter instead of Yes/No.
1 will turn on Box 1, 2 will turn on Box 2, etc... 5 and above will turn all boxes off.
Message 5 of 10
What was your workaround?
Regarding new question, what exactly do you want to do?  What do you mean by " only be able to Select 1"?
...if you are thinking what I'm thinking you are thinking, that would require one looooong formula of nested if statements evaluating every combination of possibilities.
Message 6 of 10
cwilliamson232RQ
Well when i have 2 Check Boxes I can just say   =not(OPTION 1)
But Not sure what to do when there is 4 Pick Boxes. be nice if i could say.   = not(HEIGHT 12, not(HEIGHT 9, not(HEIGHT 8)))
My work around is kinda hard to explain. I still do not know how to basically just turn a VOID on and off.
I can trick the VOID to make it be negative but it now what I want to show.
Is there a way to be able to just TURN on and TURN off a VOID ?
Message 7 of 10
Yes, that's different from turning OFF the void. You are changing the extents of the void, but the void must cut at least 1/32" of the geometry in its "OFF" state.  The attached void cannot be controlled via a visibility parameter as I stated.
Message 8 of 10
Voids cannot be associated with Visibility parameters.  You need to give the void a length parameter and control the parameter in order for the void to cut or not cut the solid.  Then you can associate this parameter with a yes/no box.  Zip and share your family if you need it to be looked at.
Message 9 of 10
cwilliamson232RQ
see attachment.
Message 10 of 10
For this particular family, just add a flip control.
