Per the images, I have a sink and a countertop (2 separate components). The sink should be visible but for some reason it doesn't show up unless I hover over it or the counter, as I was in the image. Any thoughts?
Thank you
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Some ideas...
...try giving the sink a slight offset from host plane in Project. (via "Elevation From Level" parameter)
...open sink family and make the Model Geometry Visible in Plan/RCP.
...open countertop family and remove or hide mask in Plan View and make the Model Geometry Visible in Plan/RCP.
This AKN Article may explain what is going on in your case and how to correct it :
I changed the Model Geometry Visibilities and it worked perfectly! (the slight offset worked too) Thank you sir.
