09:27 AM
- Mute
- Permalink
- Report
Hi all!
When trying to generate a void in the border of a slab, I would like to do it directly without doing one of the next things:
1- Instead of the floor, generate an in situ modeled component. If I do this, I've to be very careful when I create schedules selecting not only by family and type of the typical floor, I'll have to select the in place model too.
2- Create a floor with different thickness and bottom offset to make this part.
Does there is any way to generate this void keeping the floor element without adding modeled in place/suplementary parts?
Thank you!
