- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've set up a circular void family to create custom perforated screen on a wall face. It's been working quite well (albeit a bit slow due to the number of them) and I could copy and paste the voids and and adjust the sizes quite easily. Now when I select one or multiple and change the properties to a smaller/larger void, or copy, or even insert a new one, it does insert/copy/change but will no longer associate the affected void to the wall, ie you can't see it, but when you hover over it it highlights like it is there. I've tried deleting some and then restarting, but no luck. I've tried using a computer with more memory and the same thing happened. I've tried selecting new host, editing work plane, picking new work plane, joining, cutting, etc and none will associate the void family with the wall any more so it won't cut the void out. It worked before, so I can't understand why it no longer works... Any thoughts? Typically, I was almost finished... The same thing is now happening with the reveals on the wall.
