Dimension offset revit to pdf
mike
mike
I have attached an image of a job that i'm currently working on.
On the left is the revit drawing and on the right is the pdf of the revit drawing.
I noticed on site that the dimensions are offset and some are up to 50mm out!!!
This has caused a lot of confusion and potentially could have ended up causing mistakes during construction.
Can some please explain.
Tai
Which PDF printer do you use? Have you tried any other ones?
mike
Scansoft PDF create
I don't use that so I can't say anything. Maybe try PDF Creator or some other see if the problem persists.
