Void extrusion not working on Sweep objects
13 REPLIES 13
Message 1 of 14
1848 Views, 13 Replies
As stated in the title sweep object not working with void extrusion.
Labels (1)
13 REPLIES 13
Message 2 of 14
The void and the solid should be in the same family.
Message 3 of 14
Void seems to be cutting fine on my end.  Did you post the correct file?
Message 4 of 14
...this void?
Message 5 of 14
in reply to: barthbradley
It's the correct file, I have just added a screenshot of where I want the void to be, welcome to refer to that image
Message 6 of 14
They cut fine here...
...you need to select and cut each solid component with the void.
Message 7 of 14
WHAT!? how come?! Mine is not working...Would you mind to send me the file you downloaded..
Message 8 of 14
Dunno.  Are you selecting and cutting each elements you want to Cut with the Void? Separate transactions?
Message 9 of 14
I think I know what's going on. You want to cut multiple solids with the same void, but you don't see the void once you cut the first solid.  It's still there. It just isn't in an "unattached" state. That is, it isn't orange and visually detectable anymore.  But it is still there and selectable with your mouse.  Click on Cut Geometry, select the solid to cut and then hover your mouse cursor around where the void is located until it highlights blue -- and then snap on it!
Message 10 of 14
So, how'd I do Flora?
Message 11 of 14
It's cutting fine and you need to select and cut each solid component with the void.
Which Revit version are you using?
Message 12 of 14
lim.wendy
Hi @Anonymous,
Thanks for posting. It looks like @barthbradley  found the cause and gave you suggestions on how to resolve this, so for now, I am going to mark this as "Solved". This won't prevent other members from commenting on this question though in the event other ideas come up!
Thank you @barthbradley !
Let us know how things are going!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 13 of 14
in reply to: lim.wendy
Never mind me, Wendy. I'm a big fan or yours. I sincerely hope everything is going well for you.
Message 14 of 14
I was having the same problem. Thanks for your answer, that realy help
Forma Design Contest
