Visual Display of Window Family
5 REPLIES 5
iustinXVWHB
411 Views, 5 Replies
I have the window family loaded into the project.
When I am in Hidden Line view, I cannot see all of the window frame.
When I am in Realistic View, I can see all of the frame.
Could you help me adapt the family to show the complete frame in all Visual Display modes.
Labels (3)
5 REPLIES 5
in reply to: iustinXVWHB
I don't understand this Window family.   It looks like it's modeled incorrectly.
No visibility issues here with this Window Family in my Project. The issue must be related to a setting in your Project.  Post the RVT here.
iustinXVWHB
in reply to: barthbradley
It is intended to be used as a corner window.
So when it is in Realistic mode it shows the 3 panes.
But when I look at in Elevation it looks like this.
Thanks.
Delete the "MC01" Nested Family and reload into Project.
BTW, the Family isn't built correctly. Change the thickness of the Host Wall in the Project and see what happens to your Windows.
...actually, instead of deleting the MC01 nested Family, just change its Visibility Settings. Uncheck Front/Back.
iustinXVWHB
That seems to have worked. Thank you.
Forma Design Contest
