Visible portion print extents different from default
gnarkill283
Message 1 of 9
gnarkill283
I have a project I need to print out blow ups for which could be done quickly by using the visible portion of current window option when printing. For some reason though the extents is much bigger when printing and I have no idea why. Here is what it should do:  image.png
here is what it does instead:
Replies (8)
Message 2 of 9
Print Setup:
- Zoom: fit to page
Message 3 of 9
gnarkill283
Both pics have that setting on: image.png
Message 4 of 9
Is that an actual Print Preview you are showing in your screenshot.  Strange looking UI.
Message 5 of 9
gnarkill283
Thats adobe acrobat on the right
Message 6 of 9
You know, I just went through something like this a few days ago. It believed I resolved by changing some setting in Adobe from "user" to a standard page size.  I just can't remember how I got there.  But it was definitely through Adobe.
...Maybe I screwed around with these Adobe settings and fixed it.
Message 7 of 9
gnarkill283
It has the weird extents with both adobe or xerox printer: image.png
Message 8 of 9
Have you tried Landscape orientation under Print Setup?
Message 9 of 9
You sure your Print Range is not set  to Visible Portion of Current Window?
