I have Revit 2018.
I am trying to change the structural framing type of a truss.
In the Properties window, the only options currently available under the "Structural Framing Type" are "Set Framing Type" and "W Shapes: W12xX26". I want "dimensional lumber" as an option.
How do I load in a different material, such as dimensional lumber, so that it is available as a framing type option in the Truss Properties window?
All of my attempts to load materials so far end in the error message "The family is not of the correct category."
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Load the Type into the Project first. If it's a Structural Framing Type, it should appear in drop-down list.
FWIW: if you load the Structural Framing Family and place one instance of it in the Project, and then draw your Truss, the Truss will use that Structural Framing member by default.
Never fails. YOU come in and say the same thing I did and score the solution credit. What's your secret? Being second?
This is just a test post.
@barthbradley wrote:Load the Type into the Project first. If it's a Structural Framing Type, it should appear in drop-down list.
Huh? There's only a handful of ways to LOAD a family into a Project. You can any or all of them to LOAD a Structural Framing Family. There no "special" way to LOAD a Truss member. Besides all that, the issue was not LOADING -- it was loading the correct CATEGORY. In your case, STRUCTURAL FRAMING MEMBER CATEGORY.
FWIW... "Material" (as in ""how to load the material") means something entirely different from what you are talking about.
I'm doing exactly as both of you say - when I switch the Structural Framing types, the webs and chords disappear!
Fine.
Switched from this
to this -
and then the truss disappears.
You don't say.
Pretty quirky. Does it happen with other Materials too? Try Carpet.
The Dimension Lumber family also has the correct visibility.
Happened with the W section too
Maybe the Motherboard inhaled some second-hand cannabis smoke?
Kidding.
Can you post the file?
@barthbradley - stop snickering....
Here you are.....
