Visibility problems - extra lines in corners
6 REPLIES 6
APL.Revit
364 Views, 6 Replies
I have problem with visibility of my model. These are generic model in place and in 3D view Revit displays it with such weired line on corners of shapes. How to get rid of them??
6 REPLIES 6
rxi.gg
in reply to: APL.Revit
can you upload the model to check?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
You probably created that linework in the family with Model Lines. Go into Family and Convert them to Symbolic Lines.
Turn off any imported or linked DWG see what will happen.
APL.Revit
in reply to: rxi.gg
Unfortunatelly I cannot share the model file, its a model file from work.
Its not model lines.
I turned also of all import/link dwg, didnt help. The problem does apply to all elements I create, not only generic modells or model-in-place. It a problem in all graphic display modes actually now I see.
rxi.gg
could be the graphic card drivers not updated?
APL.Revit
in reply to: rxi.gg
The problem occur only in this model, there is no problem with other files I work with. I did also purge unused and audit, turned off all linked files, deleted 3D view and made new one - doesnt work.
I found the answer in this thread! :
https://forums.autodesk.com/t5/revit-architecture-forum/extended-lines-in-3d-views-problem/m-p/90537...
Solution: there was some object (in my case dwg link) which had greater extends then maximum distance limit that Revit can handle. I deleted then and it works now
