Now after fixing the exterior wall issue which deleted all my rooms and tags, I can't seem to bound a room to any of the multiple spaces that I had previously created. This is a warehouse that has some smaller height walls in this expanse. When trying to create a room assignment within 4 walls all it shows is a box and I have found nothing on internet that fixes the problem. All walls roof and floor have room bounding switch on.
I think it is normal like it was when I had room names. This is one cooler in a warehouse with a rollup door but the ceiling is lower than the height of space. There is a floor and roof on this and other rooms and the main warehouse.
Thanks for your help.
One big floor for the entire building but quite sure if that has anything to do with it. Floor and roof was placed after the troubles and I didn't realize till it was too late.
Looks like one or more walls are not bounding properly. A quick fix would be to trace the Walls with Room Separation Lines. As you are doing that, you might stumble upon the "bad" wall.
Update: It had something to do with the flor and/or roof. I deleted them both and rooms were able to be normal again. Now I just have to figure out if I can put a new floor and roof back in.
