Visibility of nested outlet symbol in Specialty Equipment Family
hshewakena
Message 1 of 13
hshewakena
I have a shared nested Electrical Equipment family inside a Specialty Equipment family. I want to control the visibility of the outlet family in plan and elevation separately. When I turn off Left/Right in Graphic overrides the Front/Back visibility will also be off. Anybody had such problems and sort out? Before I conclude it's sort of a bug. Thanks.
Replies (12)
Message 2 of 13
Can you post the file?
Message 3 of 13
Is it a face based family?
Message 4 of 13
hshewakena
It is a wall based family. I have the same thing in a non face/wall based family and It doesn't have a problem.
Message 5 of 13
hshewakena
here's the family it is a wall based TV niche
Message 6 of 13
Work correctly here. Did you have them turned on in elevation?
Message 7 of 13
hshewakena
Yes, you need to turn off the Left/Right and load it to project then You wont see them in front elevation. I've checked on the visibility that's placed as instance parameter also.
Message 8 of 13
What I am saying is I did do that, and the symbols show in Project Elevation.
Check your VGO's in Project.
Message 9 of 13
hshewakena
Did you uncheck the Left/Right before you load it. It is still not working for me.
Please see attached.
Message 10 of 13
Yes.
Did you test in another Project?
Message 11 of 13
hshewakena
Yes, I did.
Message 12 of 13
Well, it ain't replicable at my end, so I'm at a loss to explain.  Here's a list of 33 things you can check. Obviously, not all apply  -- but, I'm sure one does.
 https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 13 of 13
