Visibility hierarchy question
ct_studio
Message 1 of 12
ct_studio
Trying to override this wall using EOD while all walls in the view are set to halftone, but it doesn't register the override. Can one not override a category-wide halftone?
Replies (11)
Message 2 of 12
jay_colc
Have you selected the Wall then typed EOD?
I can override a Halftone Wall with a Graphical Override for this View - is this what you are looking at?
Also if it is in a linked file it you need to tab to select it but will act differently than a wall directly in the model.
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 12
hmunsell
for future reference....
Howard Munsell
Message 4 of 12
ct_studio
I think that's what I'm looking at..
there must be something else going on
Message 5 of 12
jay_colc
Is there a linked file in your model as this shows grey?
Also check you have no Filters applied to the View (from which he Visibility Graphics > Filter Tab)
Jay Colcombe
Message 6 of 12
hmunsell
since this is the Architectural Forum and you're trying to override a Wall.... is that wall in a different phase? as in your View is set to New Construction and the wall is in the Existing phase?
or as @jay_colc suggests, is that wall coming from a Link?
Howard Munsell
Message 7 of 12
ct_studio
no links or filters
Message 8 of 12
jay_colc
Then as @hmunsell @suggested check Phases,
Also Look at Discipline in the Properties palette and finally object styles?
Jay Colcombe
Message 9 of 12
jay_colc
I think we are looking at this wrong, it’s the black line that’s the issue, can you Tab Key and cycle through to see exactly what it is related to it should give an indication in a properties pop out window
Jay Colcombe
Message 10 of 12
syman2000
Check the phase graphic override
Message 11 of 12
ct_studio
I think that your override is still showing a halftone green.
Message 12 of 12
jay_colc
Yes, if you look at my images I set halftone using VG (Visibility Graphics)
Then in the View I selected the wall > Right Click > Override Graphics in View by Element. (You can even halftone it again here!)
I picked a transparent Green using the Colour Slider and pushing the slider on the right to the Top
Jay Colcombe
