How to join walls
How to join walls
mwang7DKXEF
Message 1 of 8
How to join walls
mwang7DKXEF
      I have idea how should I make 3 walls join together.
Thank you
Replies (7)
Message 2 of 8
jay_colcombe
Due to the difference in build-ups it’s not going to be straightforward.
You could first try the Wall Join Tool and investigate the different arrangements to see if you can find a solution.
Alternatively, Disallow join of the thinner wall and drag the wall
end node to the corner wall arrangement and then use the invisible Linework tool to hide the join line.
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 8
mwang7DKXEF
Thank you so much. very helpful.
Message 4 of 8
syman2000
Can you post 3d screenshot of this wall. I assume the wall edit may cause wall join conflict. Try to reset the profile and join the wall together.
Message 5 of 8
mwang7DKXEF
Thank you so much for replying. I will show you that wall. That wall I edited, so that it can touch irregular ceiling.
Message 6 of 8
mwang7DKXEF
          This is Edited Wall.
Message 7 of 8
syman2000
Thanks. I would reset the wall profile and then attached the wall to the ceiling. Once you done this, your wall joint will resolved itself.
Message 8 of 8
mwang7DKXEF
Thank you so much
