virtual tour
virtual tour
Grover_Puma
Advisor Advisor
Message 1 of 12
virtual tour
Grover_Puma
Very good to all, I have been 48 hours without solving this and I have not been successful
I have a virtual tour to do and then I get an error, for more details I leave a link to publish in forums in Spanish. regards
https://forums.autodesk.com/t5/revit-bim-360-espanol/recorrido-virtual/m-p/10342549#M19061
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
Replies (11)
Message 2 of 12
RDAOU
@Grover_Puma
  • Are you trying to do a walkthrough?
  • What is the error you are getting?
  • There you mention a card setting you messed with...do you mean: File >> Options >> Hardware >> Use Hardware acceleration? if yes, keep box unchecked - off
type %TEMP% in the Windows Start Menu Run/Search box and delete everything in that folder. Restart revit and run the walkthrough with Use Hardware Acc off ...then post here the error if you get any
Message 3 of 12
Grover_Puma
Saludos!
Message 4 of 12
RDAOU
@Grover_Puma
Sorry can't tell much from that error... can you upload the journals? it should be located under
%LOCALAPPDATA%\Autodesk\Revit\Autodesk Revit 2021\Journals
C:\Users\YOUR WINDOWS USER\AppData\Local\Autodesk\Revit\Autodesk Revit 2021\Journals
Message 5 of 12
Grover_Puma
I found the files you mention, what do I do with them?
Saludos!
Message 6 of 12
andre.micka
I remember having the same problem and I found it was related to my driver's Logitech webcam. I can't find the post ...
Message 7 of 12
syman2000
Can you upload the file so we can see if we able to reproduce your error? Also what is your computer spec.
Message 8 of 12
Grover_Puma
saludos
Saludos!
Message 9 of 12
Grover_Puma
I think the problem is going around here because yesterday I was on a video camera and it worked for me, stop making video camera and I think it no longer works ....... hopefully you can find it, greetings
Saludos!
Message 10 of 12
Grover_Puma
it is a third generation i7 windows 10
Saludos!
Message 11 of 12
syman2000
I have no issue exporting the walkthrough. It could be your hardware having low memory.
Message 12 of 12
Grover_Puma
Finally solved !!!
I decided to completely format my laptop
after several attempts like
1 update driver
2 update NVIDIA card
3 run as administrator
4 when opening carry out audit or review
5 install and uninstall revit
............etc
When formatting the machine I realized that the space it had was about 10 GB on disk C and since Autodesk does not let you install more than disk C, because this was already completely full, when formatting and now have more 50 GB of space on disk C, because now it works for me to just open the file and do the virtual tour, as if nothing else.
without having to do the rest.
Well, in summary I consider it was the space of disk C
I do not see another reason, so I solved it.
Saludos!
