Views Not Cropping Matchlines in dependent views
Message 1 of 21
Is there a way for you to make Matchlines react to cropped dependent views? we are having issues getting them to cooperate across multiple views due to this not working.
We are having to "notch" out our crop regions in some views for legends and such and the annotation crop is not mimicking our cropped view causing the Matchlines to continue to show up through the Annotation crop region and hence show up through our legends etc.
Thank you for any assistance.
Replies (20)
Message 2 of 21
joe_keogh
Hi @Anonymous
I would expect to see a matchline parallel to the crop, as opposed to perpendicular?
As in "FOR CONTINUATION OF PLAN, REFER TO A01.02", What is your Matchline referencing?
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Message 3 of 21
Matchlines extend to the View's annotation crop.  So adjust the annotation crop if needs be.
Message 4 of 21
this is just an example, we have a VERY large building, so we have matchlines going horizontally and vertically.
Message 5 of 21
we do that as well, the problem is that we cannot adjust just parts of an annotation crop. we need it to be where it is in other places.
Message 6 of 21
Martijn.Pater
...I guess use several matchlines (or have the sketch follow the crop boundary)?
Message 7 of 21
Martijn.Pater
...or maybe edit the matchline and remove part of the line where its extending the cropregion?
Message 8 of 21
Then you need to create multiple match lines, terminate them where you want to break, and manually hide in dependent views.
Message 9 of 21
Martijn.Pater
hmm I was thinking something more like this... but then again I may have misunderstood the screenshot. edit: I guess the above makes more sense actually^^
Message 10 of 21
Yeah, i know about this already, i was trying to find an easier less time consuming fix that doesn't add elements to a project that is already bogged down because of how large it is.
Message 11 of 21
Would have been nice if you could tell us you knew about that already so we needed not to bother you with a redundant workaround.
Message 12 of 21
Sorry
Message 13 of 21
RDAOU
who is complaining about redundancy 🙂 this whole forum is full of it ... one extra redundant reply won't really matter
@Anonymous
Talking about redundancy, I'm sad to tell you that there isn't really any easier way/workaround for this ... you will have to suffer the extra clicks or if your clients are not really that picky just live with it as it is until Autodesk modifies the annotation vs view's crop behavior. There was an idea posted on the Idea forum but wasn't popular to get enough votes.
Message 14 of 21
yeah, that seems to be the case. I found a temporary workaround using a mask that is less cumbersome but still not ideal.
Message 15 of 21
A mask?  How?  I thought masking regions couldn't cover annotation objects including match lines.
Message 16 of 21
Martijn.Pater
@ToanDN (almost white) text? (...as in, I don't know what he means aswell)
Message 17 of 21
I found it in another forum. its called an Uber mask by them, i changed the name for my own filing purposes. But i attached it.
Message 18 of 21
this one can cover annotations and the like as well. its slightly cumbersome to use, but it works for my purposes and doesn't require the tedious work of have a ton of matchlines and shortening and lengthening and hiding etc.
Message 19 of 21
Interesting.  Thanks for sharing.
Message 20 of 21
Martijn.Pater
Annotation masking region! close enough guess I suppose^^ Quite a nice method though. You should mark your own answer as solution to this particular question...
