view templates
view templates
view templates
 How do view templates work? Can someone explain me how does it work? what is a view template for?
Diego.Faria
"A view template is a collection of view properties, such as view scale, discipline, detail level, and visibility settings.
Use view templates to apply standard settings to views. View templates can help to ensure adherence to office standards and achieve consistency across construction document sets."
Check this link for more info:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Diego Faria
LinkedIn
s.borello
See link below... lots of videos explaining Revit view templates.
https://www.youtube.com/results?search_query=revit+view+templates+explained
martijn_pater
View templates are used to control view settings for multiple views. ie. if you have multiple sections and you want to show all of them scale 1:50 you can lock the view scale to 1:50 in a template. If you would change the setting to 1:20 scale in the template, all your sections with this view template applied will then become 1:20 sections. Not the best example to use scale maybe, but this goes for all view properties, ie. category overrides/view filters etc etc.
