view ref tag
view ref tag
view ref tag
Where do I find view ref tag.
My tag  in plan just say Ref and in type properties none.
how to I set to ref tag to read properly ?
I am not sure if we are talking about the same thing but the screencast below shows a simple example of using Match Line and View References.
Thanks for the screencast,
loaded tag from OOTB family. tag was seating in symbol-tag-arch-view ref.
its now referencing correctly.
rbensleyDLXB4
Community Visitor
Community Visitor
Can you elaborate more on the fix. my view reference is still just showing up "REF" when i place it on the view.
munderwoodX73WC
Go to Insert tab and then under Load from Library, click on Load Autodesk Family. Search for "View Reference" and load it into your project.
If this does not resolve the issue, click on your view reference text that is showing up as "Ref" and under the Properties panel, go to Edit Type. If the Value column for View Reference Tag is showing <none>, click on the drop down for it and select View Reference. Click Apply and that should resolve the issue.
sakshi_handeXBCEG
Community Visitor
Community Visitor
Can't find View Reference in Load Autodesk Family.
