view range
view range
view range
why does revit not do a view range option, so you can actually view by coloured lines your view range settings, be so useful to have
you woull be able to open an elevation, be able to see your view range setttings and be easy to adjust by visually seeing your ranges
filipefrancisco
First of all, welcome to the Community
You can do that in VG (visual graphics), use filters with colors
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
Hi
Can you explain further, have a tutorial? I know about filters but how can you create your view range using filters
Can you advise would be most helpful
Regards
Keith Williams
BIM Manager
[cid:image001.gif@01D03FB6.B38E9C90]
22 Nicholas Street
Chester
CH1 2NX
Tel : 01244 503 800
Dir: 01244 503 8??
web : www.esdltd.co.uk
e-mail : name@esdltd.co.uk
[cid:image002.jpg@01D03FB6.B38E9C90]
[cid:image003.png@01D03FB6.B38E9C90]
[cid:image005.png@01D03FB6.B38E9C90] [cid:image006.gif@01D03FB6.B38E9C90] [cid:image007.jpg@01D03FB6.B38E9C90]
CIBSE LCEA Certification number : LCEA029959 / LCCSIM029959
The information contained in this e-mail may be confidential and/or privileged and is intended solely for the person(s)
or entity(s) to whom it is addressed. If you are not the intended recipient of this e-mail please contact the sender and
delete the information from your computer. The use, disclosure, copying or distribution of this information by person(s)
or entity(s) who are not the intended recipient is prohibited. We have taken reasonable precautions to ensure that this
e-mail has been swept for viruses, we cannot however accept any liability for any related loss or damage that you may
suffer as a consequence of our transmission of this e-mail.
[cid:image008.jpg@01D03FB6.B38E9C90] [cid:image009.png@01D03FB6.B38E9C90]
4163
This message has been scanned for malware by Websense. www.websense.com
