View range still showing object above the top line
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I am trying to do a floor plan on a 5 story building, the picture below is of the second floor, however there are some objects on level 3 that are showing up. some of the things I've tried to do :
- Check View range is top is set below unwanted objects
- check to see that there are no plan region in area
- check to see that the unwanted object is set to level 3 NOT in the second floor, though I found that if i offset the unwanted objects 1' up it does fix the issue. I just want to fix it correctly.
I've included the pictures below of the view and the view range, I've circle the unwanted objects that are showing as well
