View range options disabled
Message 1 of 8
The view range tabs are disabled as shown in the attached image.What could be the reason and how can I change it?
Thanks in advance
Replies (7)
Message 2 of 8
ennujozlagam
maybe this explanations helps. thanks
Message 3 of 8
Basam.Yousif
Because selecting the cut plane is limited to only the associated level of the plan view and can't be changed.
WHY do you want to change it?
Message 4 of 8
Thanks.When my view depth is increased, the door sill is displayed ,even though cut plane is same.I want to get the lower stairs displayed-but with out the door sill on.Is thay possible?
Message 5 of 8
RDAOU
@MALINIS1
The offset for  "Primary Range Bottom" and the "View Depth" got grayed out because you have aligned the Level Datum "Garage Door" with the associated level of the view..."FIN.LIBR) … Revit will not allow you to apply the settings and forces you to cancel.
To fix that, you need to do either of the following:
  1. EITHER...Change the "Primary Range Bottom" and "View Depth" to level below
  2. OR... Nudge the Level called "Garage Door" downwards
  3.
...If you need further assistance in setting the view range you need to provide a section view highlighting the levels and what you want to see (or not see)
Message 6 of 8
I saw @RDAOU post in my email but not here. What gives?
Message 7 of 8
RDAOU
Seems it got spammed again... I think the @Discussion_Admin is going to hate me as much as I report missing replies
Here goes the reply again:
The Primary Range Bottom and the View depth get grayed out when you align the set level (in your case the level datum called "Garage Door") to the associated level of the active view (ie: in your case the Level Datum called FIN.LIBR)...when that happens, Revit does not allow you to apply the view range setting and you are forced to
  1.  Either Cancle
  2. Or set the "Primary Range Bottom" and View Depth to "Level Below"
To set the above to the level Datum "Garage Door" you need to nudge/move this level downward from FIN.LIBR
See screencast Below
Message 8 of 8
martijn_pater
If you just want to adjust view depth to show your stairs you could use Plan Region.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
