Hi!
I'm currently trying to hide grid lines from a linked revit file, but after opening the Visibility/Graphic settings and clicking Revit link, the display settings aren't there. A video said it should be there so I can change the display of those lines and other items from the linked file.
Thank you in advance for your help!
Thanks for replying. Unfortunately, it takes me to the same screen and I have the same problem - no display setting column.
This is weird issue ....
What is your Revit build? Did you consider installing any updates? Make sure your Revit build is the latest - that is important. Use the Desktop App (and make sure the DA itself is up to date!) then relink the model and see.
is this issue happening with all models or just this one? what if you make fresh test models - do they get this issue too??
