view range issue
view range issue
roscopeco2000
view range issue
roscopeco2000
i thought i understood view range but the grey line outside my wall construction below is my roof construction its non selectable, so i cant hide it either. I have tried playing around with the top plane and cut plane but it still displays how can i get rid of?
Ilic.Andrej
Select the floor plan view and in properties palette, set underlay: none
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
roscopeco2000
ok in the floor plan properties how can you set underlay to none? there doesn't seem to be option to do
Your mouse cursor is already on it - First Floor box next to Range: base level. Now click.
Ilic.Andrej
Play with this options
Andrej Ilić
MSc Arch
roscopeco2000
LEGEND!!! THANKS
chrisplyler
If your problem was solved, please select one or more of the posts as Solutions to the thread.
