hi there,
someone has sent me a navisworks file (nwd) i would like to open it in revit and make some schedules, is this possible?
thanks
You can import de NWD file in Revit 2018.1 or above. In this version has a cordination model import button for directly import Navisworks files. But this process don't allow you extract quantities or make schedules about imported file, this is just for cordinating the model process.If you need extract quantities for nwd file, I suggest you use Navisworks because it have a quantities extract function for this case.
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community!![]()
Please see the article HERE for a step by step process to link Navisworks file.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.Kudos welcome.
Thank you,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
