Good Evening Expert
I'm going to put it out straight...REVIT Help files sometimes makes no sense and some other times they get one confused! I thought I figured out what the view range settings are untill I wanted to show some foundations below ground.
That was when I hit the ? To go to help! I thought I new something but now I am actually lost! I even lost the floor in the process! And messed up the view range settings! And I cannot get my view back to where and how it used to be!
can someone explain to me please how those bottom range and view depth work? And how shall I get the friggen slabs back and show the foundations and get this REVIT to function NORMALLY for once 🙂
I'm really sorry for for the ranting but I looked over YouTube, Google and two books on REVIT to fix what Revit Help page got me to do but somehow nothing seems to work! Already saved the file and no .001.rvt are backed up! So if I don't fix it I am simply screwed
Solved by RDAOU. Go to Solution.
Hey @JasonLLINDNER
I am not one of the EXPERTS! you addressed but I do hope this lengthy clarifications helps you better than Autodesk's Help Page.
Those View Range Settings are an added value options which Revit grants the Reviters to give them the ability and choice to show certain elements which are beyond the bottom clip. By default the bottom and the depth clipping planes are set to the same level.
Now consider we need to show some elements below/beyond the Grade Slab of Level 0 which has a default Bottom Range defined (at 0.00mm)... (say for example some services such as piping or cables or a pit or even a desk which you decided to bury below ground; ie: elements which are not considered so special to be an exception) BUT we don’t want to change the Bottom Range because if we do, some nonspecial elements among others will then be represented with Projection solid continuous lines!
The Exceptions to the above rule are Floors (architectural and structural), stairs, and ramps category elements located down till 1.2 meters deep below the bottom of the primary range. Those elements will continue to be visible and are either represented with Projection lines or Hidden lines (if concealed behind a top visible element) till they fall outside the 1.2m range below the Bottom Range (which at the present moment is still by default at same level/height/depth as the View Depth).
Once those special exceptional elements exist deeper than the 1.2m they will ultimately follow the same rule...
Example:
Consider a floor slab (both architectural and structural) placed on Level 0. When you open a default template; the view range is set as follows:
If one looks at the section; one will notices that the slab/floor is actually below the 0 level. ie: if it wouldn’t have been an exception; this slab should not show on this view because it is outside the Range (Both Bottom as well as the View Depth set at 0.00mm). But because it is an exceptional category of elements...it still shows as a projection. To better understand it... (Leave view range setting as per default values) Place a foundation next to the slab with T.O Foundation at 0.00mm for comparison
Back to the default settings of view range...
THE MISTERY OF THE VANISHING FLOORS...
FLOOR are special exceptional elements as mentioned above…BUT once they are transformed to parts. They disappear in the plan view because PARTS are normal nonspecial elements just like the buried desk mentioned above. Hence treated the same
To fix that you can do one of the following:
Hopefully the above wasn't boring 🙂 see the screencast below (Revit Files are also attached)
you can have a look at this article you fully understand the theory of revit view range :
https://bimandbeam.com/2022/01/revit-view-range-html/
Stop spamming the forums.
