Hi there
I have 5 years experience in Revit and View Range still baffles me.
I work at an architect in Denmark and my engineer’s model is linked into my architectural project. The columns in my engineer’s model has a console, which I do not want to show in my project. But If a try to change the view range, the console still shows.
What to do?
I have attached a few images of my problem:
1: 3D view of column with console
2: Plan view
3: Section view with view reange
Solved by Mirko.Jurcevic. Go to Solution.
If might be the column family issue.
Edit the family and uncheck "Show family pre-cut in plan views" option.
Load the column and see does it show the console now. If yes, then the person responsible for the link should make this change in their model.
We call that a "Haunch" but i believe its that same thing. it depends on how that was drawn. the Haunch/Console is not a standard Revit category. They could have drawn it in a number of different ways. My engineers either use a In-place Component (modeled-in-place) or a Generic Face Based Family that is reciprocated to Columns and placed on the Column in the model. It could also be modeled into a custom column family.
Howard Munsell
Hi Mirko
Your solution fixed my problem! Thank you very much.
Best regards
Jens Lillebæk
No problem, glad it worked out for you!
