View Problem
View Problem
View Problem
Hey all! So I was working on creating a curtain system and now i can only see the one wall I was working with. I can see the rest of my structure in the floor plan so I know its still there, but I cant see it in 3D view. I have checked hidden elements and that is not the problem. I exited out and when I went to go back in, even the main clip of my structure is now just that one wall. Again I know its still there because I can see the rest of the structure in every other view except for the primary 3D view. Any help would be greatly appreciated!
THanks,
Meg
RDAOU
@Anonymous
With only you able to see the model its hard to make assumptions why your walls are not visible! there are over 50 reasons why things vanish or go missing in Revit...
For a start (if you are unable to share the model) have a look HERE ON THIS LINK see what @SteveKStafford wrote there...
David_W_Koch
Welcome to the community!
Are you using the 2016 release?  If so, could you have used the Selection Box tool?  With no objects selected in your 3D view, on the Properties palette, try unchecking the Section Box parameter (Extents category).
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
