- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I thought this would be simple but I'm hitting a roadblock. We are constantly manually hiding objects in our site plans that are part of the building model but not relevant to the site plan.
I made a shared parameter yes/no "Show on Site Plan" and loaded into the relevant families, of many types (electrical equipment, light fixtures, mechanical equipment), with an idea to make a view filter that would hide any item without this parameter in a checked state. So the filter would catch instances where the parameter is not assigned as well.
The problem is that this shared parameter is not available for selection in the filter rule dialog when I select any of these family types, let alone all of them. There is no "more parameters" option. The documentation says view filters can act on shared parameters but I'm not seeing this working.
is there a way forward here? I could consider making site plans "coarse" and editing all of our content appropriately. Is that a better route?
thanks
