I have been having an issue with export hatch to .dwg. I have family with nested Detail Items - filled region (pattern) with transparent background. This family is putting on wall so cut patterns are overlapping like in screen. Problem appears when I try export to .dwg views. Some views exported in a right way, when I delete family, wall's hatch still exists below, but in other view hatch below family are deleted. Views show the same level and project's part. I tried to create templates from both views, add this views on one sheet, check all visibility and export settings, but still views exporting in different way. I need both cut pattern (family and wall) to be fully exported. I will be very grateful for all the help.
I don't think family is a problem. In other model export looks properly.
