View call out not cutting with match lines.
How can I get the callout to cut with my scope boxes and match lines? I have large callouts that go off of the page.
sureshchotrani
Wellcome the Answer Day:)
You can reduce the scale of the view.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
MichaelBussiere2
Thank you for your post. You should be able to resize the scope box as well and adjust (per above) as needed. I have included a link below with details on this. I hope this helps.
Resize Scope Box: http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU...
View Scale: http://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit...
For additional Reference,
View Callouts Overview and settings: http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU...
Michael Bussiere II
Support Specialist
Product Support
Autodesk, Inc.
dplumb_BWBR
Dan, I think you're talking about a problem I've had as well.
Suresh and Michael, I believe Dan is talking about the Callout boundary line.  When you use a Scope Box on a View with a Callout on it, the CAllout boundary extends past the edge of both the Crop Region and the Annotation Crop. (See attached image)
The Callout Boundary should respect the Annotation Crop.
russell.killian
Observer
Observer
I am also currently having issues with this. The boundary of my enlarged plan view (callout) does not crop with the scope box (even with an annotation crop). Has anyone found a solution yet?
jkarben
No real solutions other than using two crop regions, one on each side of the match line, referencing the same enlarged plan.
