Video driver error for Revit 2017
Message 1 of 8
I installed revit 2017 on windows 10 64bit and I keep getting a video driver error must exit message before it crashes. I tried updating my graphics card and java as well as reinstalling revit and I keep getting the same error.
Replies (7)
Message 2 of 8
RDAOU
@Anonymous
That depends on which Graphic Card  (Type/Brand/Mod/Speed)  you have installed... Try the following
In Revit OPTIONS: Under Graphics Tab >>>>> Uncheck the "Use Hardware Accelleration"
Message 3 of 8
Maybe upgrading to 2017.2 will solve?
What card do you use?
Can you access Graphics under Options before crashing to see Video Card Driver Status?
Message 4 of 8
tugasdotdadakan
Community Visitor
Community Visitor
i've got same trouble here . i try to disable hardware acceleration but have same result . any another solution ?
Message 5 of 8
THANKYOU SO MUCH!!!
Message 6 of 8
It works, thanks Mate!
Message 7 of 8
 Unchecking the "Use Hardware Accelleration" works great! Thank you!! 🙂
Message 8 of 8
I had the same question. Also asked in the forum. No one responded and then I continued to search. I met your answer. Then I remembered that this also happened at Autocad 2019. He therefore does not recognize the video card and therefore gives an error message. Thank you so much, that I could still find it.
Greeting,
John
