Very distorted edges
9 REPLIES 9
Message 1 of 10
sdwinslow
1029 Views, 9 Replies
I cannot get this building model to have clean edges - I have increased the view size to 100" wide to try to get the lines smoother but doesn't help.   Also I can't get the fence to show without a lot of distortion - See attached image...Any advice?
9 REPLIES 9
Message 2 of 10
in reply to: sdwinslow
Set the camera's Eye Elevation and Target Elevation the same height so that you have a true 2-point perspective.
Message 3 of 10
sdwinslow
in reply to: ToanDN
Thank you,
That cleaned up the fence nicely, but the doors, canopies, and curbs are hard to read...I set the detail level as "fine" but doesn't change anything...I attached a close-up.  More advice?
Message 4 of 10
What are your render settings?  Does it look zagged if the view is set to shaded or hidden?  Do you hvae any CAD file in the model?  If so, turn it off for this view.
Message 5 of 10
sdwinslow
in reply to: ToanDN
Thank you for your response.  All of those settings have the same edge distortion - it looks clean in the elevation views...
Message 6 of 10
Can you create a default 3D view, turn on Internal Origin under VG > Model tab > Site category, do not change anything else, and zoom extent? What do you see?
Message 7 of 10
sdwinslow
in reply to: ToanDN
This is the default 3D view - the size of the crop is 280"
Message 8 of 10
Message 9 of 10
Size of the view crop has little to nothing to do with the issue.  Can you turn of the view crop and zoom extent?  It would be easier if you could share the file here.
Message 10 of 10
sdwinslow
in reply to: barthbradley
Thank you - much better; I still wish the lines didn't have the thickness that they get with the anti-aliasing, but still - this is MUCH better -
Thank You!
