Cannot open Revit: Missing Schema Folder
5 ANTWORTEN 5
Nachricht 1 von 6
1076 Aufrufe, 5 Antworten
Annotation 2021-01-29 151327.pngAnnotation 2021-01-29 151237.pngI have successfully downloaded all the Revit products (for Revit 2021), but when I try to open Revit, I am met with the following message: Missing Schema Folder.
I have tried to repair and reinstall but I still have the same problem. I also do not have access to a working Revit to replace the schema folder.
What should I do?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Nachricht 3 von 6
Nvm. I found the solution.
Nachricht 4 von 6
If it's alright with you, I'll leave the solution up for others to see.  Or do you want me to remove it from your thread? Let me know ASAP.
Nachricht 5 von 6
als Antwort auf: barthbradley
You can leave it up!
Nachricht 6 von 6
ahmadfiroozi000
I had this problem, one of your hardware is poor, so Revit can't open, you better install the old version for example 2019
