vertical ceiling elements
3 REPLIES 3
6265 Views, 3 Replies
Can anyone help me out with how to return a ceiling vertically ie. ceiling bulkheads? Thanks John
3 REPLIES 3
You can do it as an in-place family. When you create the family, select ceilings as the category. After you've created the solid vertical piece (or soffit), you can assign a material to it to match the rest of your ceiling. Once finished it'll schedule out properly.
Revit has a 'soffit' wall. It's a wall type that is drawn *downwards* from the current level to a depth that's user-defined and allows for any kind of construction you might want (just like all the other walls). So then it's construction could be vertical t-bar or whatever.
So switch to an RCP, set the 'base offset', levels, and 'top offset' to jive with your ceiling vs. slab heights, and then draw your bulkhead. Better than an in-place family for then Revit know they are walls, and will deal with them as such, and allow you to change them very easily....
Thanks a stack. Will give it a try. Regards John "JeffreyMcGrew" wrote in message news:8131036.1083193633445.JavaMail.jive@jiveforum2.autodesk.com... > Revit has a 'soffit' wall. It's a wall type that is drawn *downwards* from the current level to a depth that's user-defined and allows for any kind of construction you might want (just like all the other walls). So then it's construction could be vertical t-bar or whatever. > > So switch to an RCP, set the 'base offset', levels, and 'top offset' to jive with your ceiling vs. slab heights, and then draw your bulkhead. Better than an in-place family for then Revit know they are walls, and will deal with them as such, and allow you to change them very easily....
Forma Design Contest
Technology Administrators
