Using the "Create parts" tool for a slab in Revit
mark.stigler
mark.stigler
I am creating parts from a slab in Revit. When I export the NWC they do not show up as individual parts......only the entire slab shows. Is there a way to create the individual slabs from the "parts"? The thing is I'm trying to create a timeliner with individual pours but the entire slab has been modeled. Hope this makes sense. Thanks!
cbcarch
Check here:
https://www.bing.com/search?q=show+Parts+from+Revit+in+Navisworks&mkt=en-us&httpsmsn=1&refig=410904b...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
!Dalton_Goodwin!
It is a setting you can change before exporting to Navisworks format. Should work if  I understand your question.
mark.stigler
That worked......Thank you very much! Saved me a bunch of time!
cbcarch
I think the link I sent showed that as well...………..
Cliff B. Collins
mark.stigler
Your post took me to the google page and I wasn't sure which site to go to. Thanks for the response tho!
