2019.1 Unable to select Scope Box
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
TravisVaughanKJWA
7369 Aufrufe, 2 Antworten
Anyone ever have issues with being able to select and/or modify a scope box once it has been placed?
I've tried picking on it, using a selection box, etc. Turned off Crop View, Crop Region View and Annotation Crop. Have Scope Box set to None. I see the dotted green line representing the Scope Box but I am unable to select it! Tried in 3D, plan and elevation views...
Screen grabScreen grab
Tags (2)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: TravisVaughanKJWA
Hey,
Looks like your scope box is pinned and you're unable to select it. Bottom of your Revit screen select the pin icon so there is no longer a red x and your problem will be fixed. If that icon has an X through it then any element you've pinned you will not be able to select.
Nachricht 3 von 3
mitchcantlon
late to the party here but for anyone searching for the same issue......
I couldn't select the green dashed scope box until i realised i had created it in a design option!
Once i had opened the design option for editing i could select and adjust the scope box.
Lesson to self for next time - be out of the design option before creating.
