Using Revit (or Inventor) with Oculus Quest 2
Message 1 of 9
Hello all,
I've recently got an Oculus quest 2 and am wondering if it's possible to view Revit models, turn layers on and off etc. in VR in on a Quest 2?
Hagop
Replies (8)
Message 2 of 9
RobDraw
Layers? I'd be wondering about categories if it were me.
Rob
Message 3 of 9
Hi ! I would suggest giving SENTIO VR a try. With a plug-in that can be installed in Revit, you can upload your models to the cloud & view it using a 6 digit code on the Oculus Quest 2 App. Turning layers on or off is not a feature available as of today - but it should be available in the near future. Hope this helps !
Message 4 of 9
syman2000
I use Enscape and it has built in VR mode.
https://enscape3d.com/
Message 5 of 9
Thanks but it looks like from the website Enscape is not compatible with the Quest 2? It is tethered only?
Message 6 of 9
WarrenRoberts
@Anonymous
"am wondering if it's possible to view Revit models, turn layers on and off etc. in VR in on a Quest 2"
I have been a Revit user for more years than I care to admit but I find this question to be somewhat baffling.
How does one go about accessing "layers" in Revit? I've never heard of this before.
Message 7 of 9
chillman
For DWG imports, layers are retained, and you can turn them on/off all day long.  You will find this in V/G settings under Imported Objects.
Message 8 of 9
ljamesmadison
Community Visitor
Community Visitor
I don't think he meant layers as much as objects and families.
Message 9 of 9
Lance.Coffey
Autodesk Support
Autodesk Support
The following article has info on this topic: What are the options for using VR (Virtual Reality) with Revit?
In looking online, I found that several of the options from the article include support for the Quest:
A recent change in this area is the inclusion of Twinmotion with the Revit subscription (2023.1).
Lance Coffey
Technical Support Specialist
