Ive been drawing curtain walls, but for some reason I am not able to change the depth.
Ive looked at other posts saying to go to the edit type spot to change it, but there's no dimension tab.
Gelöst! Gehe zur Lösung
Gelöst von amarkonathala. Gehe zur Lösung
Hello Caleb,
Upto my understanding, depth you mentioned is Thickness of curtain wall.
If Yes, You cannot increase the thickness of curtain wall.
But, the only way we can increase the thickness is, we have to select the glass inside the curtain wall, unpin it and in edit type you can find the thickness.
Thanks & Regards
JOSAM
Yes U can change the Thickness of Panel By accessing the panel From the Project Browser as like Below
you can chamge the thickness of the panel but MIND to create a ne type in order to not modify all your old curtain wall
If my aswer solved the issue pls mark it as solution to help other users
