I have a client i'm working with who has not settled on where he'd like to build on his site, and I'm trying to determine if there is a way to use design options (or another work around) to show different potential building locations on the site.
It'd be great if I could get the whole process to work in the DO (pads, split surfaces, cut and fill, ect.), but at minimum I need to be able to have a sheet and view showing the building at one location, and a second sheet and view showing the other. I'm trying to avoid having sheets and views exist in a separate model from the main set, but I acknowledge that one workaround to achieve this would be to have a separate site model showing the different locations and merge the sheets later.
Does anyone have a good workflow to achieve this?
已解决! 转到解答。
